EFI525 dyno data anybody? >
Old 01-11-2007 | 02:40 PM
Rage's Avatar
Default EFI525 dyno data anybody?
Does anyone have crankshaft dynamometer data on a EFI525?
Rage is offline
Old 01-12-2007 | 01:46 PM
Rage's Avatar
Default Re: EFI525 dyno data anybody?
I was able to answer my own question. 565CSHP to 575CSHP.
Rage is offline
Old 01-12-2007 | 03:55 PM
Where did you get that information ?
Phazar454Mag is offline
Old 01-12-2007 | 07:42 PM
Rage's Avatar
From a dyno test lab that tested the EFI525
Rage is offline
Old 01-12-2007 | 11:25 PM
That's better than I thought.
Revd Up is offline
Old 01-12-2007 | 11:45 PM
JCPERF's Avatar
A real good 525 will make 570HP.From Mercury they have been known to vary between 538 to 556 on average.The best 525 i have seen on a dyno was 573HP................Thats legal
JCPERF is offline
Old 01-12-2007 | 11:47 PM
articfriends's Avatar
Jeff,was that with the 77 degree sae factor or the lower commonly used one,Smitty
articfriends is offline
Old 01-13-2007 | 08:59 AM
I am pretty impressed with the dyno numbers on the 525 EFI. But why is there such a big variance in the numbers ? From app. 540 - 575 HP. Is that due to production tolerances, before/after break-in (if that makes a difference) or what ?
Old 01-13-2007 | 01:31 PM
Rage's Avatar
FYI the dyno lab that I referenced has tested a number of EFI525's and advised that they consistantly produced 565 cshp - 575 cshp. This dyno lab uses the HiPerf motor industry standard HP rating (60*F ambient air temperature) and not the SAE rating system (77*F ambient air temperature) used by the OEM automobile manufacturers.
Rage is offline
Old 01-13-2007 | 03:47 PM
I guess I'll need a new sticker for the top of my motor that says 565
raytart is offline
