power steering hard at idle >
Old 01-13-2007 | 04:54 PM
troc's Avatar
Default power steering hard at idle
Anybody ever have a problem with the helm hard to turn at idle ? As soon as rpm brought up steering is no problem. Thinking about changing pulley on pump. Any thoughts?
thanks in advance.
troc is offline
Old 01-13-2007 | 07:01 PM
monstaaa's Avatar
Default Re: power steering hard at idle
if there was no problem prior or this is not a fresh rig or install, i would check the high pressure filter.
monstaaa is offline
Old 01-14-2007 | 03:53 AM
What kind of system??? Full hyd, add on, or cable???
Add on dual ram is often hard to turn at idle.
Griff is offline
Old 01-14-2007 | 11:35 AM
I am not too sure about changing the pump on the pulley. If you double the speed of the pump at idle, you are going to double it at speed as well. That equals a lot of heat and would probably result in premature failure of the pump. If anything, I would open up the orifice on the discharge side of the pump first (as recommended by steering mfgs for dual ram, single engine setups)or as said before, find the source of the problem if there has been a change in behavior. Imco's website has the required orifice diameter and it's quick and easy to do.
Rene
oldandtired is offline
Old 01-14-2007 | 02:58 PM
Check the fluid level, consider flushing the system, consider raising idle just a tad.
handfulz28 is offline
Old 01-14-2007 | 03:38 PM
troc's Avatar
Thanks to all. I will take them all into consideration!!
troc is offline
Old 01-14-2007 | 09:07 PM
offthefront's Avatar
The stock Merc PS will do that if it needs bleeding ....Turn it lock to lock several times ....
offthefront is offline
Old 01-15-2007 | 06:09 PM
rush's Avatar
CK voltage, my boat had a dead battery on one engin and was hard to steer until the voltage came up.
rush is offline
Old 01-15-2007 | 06:29 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
How is voltage tied into rpm?
US1 Fountain is offline
Old 01-15-2007 | 10:16 PM
cuda's Avatar
I don't understand that either.
cuda is offline
