APBA Super V Light HP limit
I have heard that the APBA Super V Light has a horsepower limit of 575CSHP. Where can I go to determine if that is the case or not or better yet see a copy of the regulation that deals with this?
Thanks.
I found reference to "sealed engines" but nothing on HP limits for engines. Are there other specifications for the Super V Light racing program that includes engine HP limits?
Strock Merc 525's sealed by Tyler Crockett or Innovation. There is no specs...stock merc 525 . Innovation or Tyler will seal and put the engine on a dyno and make sure it is within merc specs.
The motors are the Mercury STOCK 525 or the Vortex HP3 or HP4 are also exceptable. This is a spec class and the motors must be non-modified and sealed by Tyler Crocket or Innovation as authorized sealing facilities. I am sure Gary and Steve, who run SVL would be more than happy to go over things with you.
Julie
Julie
Julie
Julie
This is something you should address. You really need a better way of controlling the spec class. We just dynoed a set of innovation sealed spec motors ( not ours) that are so far out of spec it's insane. I can provide the sheets if you want. Smitty
