Rudder Boat
Old 01-20-2007 | 06:24 PM
Cool Rudder Boat
Does anyone have experience in driving a rudder boat with fixed drives. What is the pros and cons. docking, steering, etc.
baja27 is offline
Old 01-22-2007 | 07:53 AM
Default Re: Rudder Boat
No one has driven one?
baja27 is offline
Old 01-22-2007 | 08:46 AM
rush's Avatar
I have 42 cabin cruser w inboards and rudders and a child could drive it,if that helps.
rush is offline
Old 01-22-2007 | 09:09 AM
Sea-Dated's Avatar
Try posting in the MTI section. I know there are several boats in there with rudders.
Sea-Dated is offline
Old 01-22-2007 | 09:20 AM
McGary911's Avatar
Forgetting about steering when backing up. You'l be using your throttles and shifters to steer the boat in reverse. I've never done this in a go-fat, but my go slow boat is twin inboard, and that's how we get it back into the slip, which can be tricky with the rippin' current by the slip.
McGary911 is offline
Old 01-22-2007 | 10:14 AM
Panther's Avatar
Frank's Marine Service
When I dock I don't turn the wheel so it's probably the same. Although, a surface drive like an Arneson may be different, not sure never had to do that.
Inboards are the easy, V drives are the easyest. They pivot really nice because the props are under the boat.
Single engine rudder boats, they suck!!! Try docking a single engine 40 ft sailboat sometime... Darn boats are useless going backwards...
Panther is offline
Old 01-22-2007 | 01:22 PM
WeaponX's Avatar
You don't touch the wheel on cats with #6s when backing or docking forward. The only troulbe with rudder is when you lose power or drive.
WeaponX is offline
Old 01-22-2007 | 03:18 PM
Brad Zastrow's Avatar
I steer my #six cat all the time docking. Backwards and foward. I even have crashboxes. Most of the time I coast in, since in gear on one engine is about 8mph.
Brad Zastrow is offline
Old 01-22-2007 | 03:20 PM
So it sounds like it would be easy to dock.
baja27 is offline
Old 01-22-2007 | 03:29 PM
No rubrail and no scratches yet. I find it very easy to dock.
