Weber carb rebuild >
Weber carb rebuild
Weber carb rebuild
Old 01-23-2007 | 07:17 PM
Default Weber carb rebuild
I have one of the Weber(Edelbrok Performer) 4bbl carbs on my 454Mag. Having just completed an overhaul/cleaning of it, I am stumped on the procedure for adjusting the Idle Speed. The guide says to back off the idle speed screw until it's not touching the lever. Then measure from the air horn to the bottom of the pump S link and adjust the idle speed screw until you get the appropriate length. Where do they consider the "top of the air horn" to be? Where do you measure from?
synack is offline
Old 01-23-2007 | 07:52 PM
Default Re: Weber carb rebuild
I always adjust set the initial idle speed based on the transfer slot. I open the throttles just far enough so that you can see the edge of the slot from below (.060 inch)
bcarpman is offline
Old 01-23-2007 | 08:02 PM
Just put it on and fire the engine. Adjust the screw accordingly by the rpm. For the idle mixture, use a vacuum gauge or just make small adjustments to get it right.
Griff is offline
teamsynergy
03-31-2008 06:07 AM
GoCiggie31
19
12-11-2006 02:21 PM
David Haag
1
09-08-2004 08:51 AM
wwwTOPDJcom
05-14-2002 08:41 PM
