42 Lightning performance #'s >
Old 01-24-2007 | 10:19 AM
ToTheMax's Avatar
Default 42 Lightning performance #'s
what top speeds is the 42 capable of with twin 700's and the NXT drives, or with twin 850's and #6's?
ToTheMax is offline
Old 01-24-2007 | 10:48 AM
FeverMike's Avatar
Default Re: 42 Lightning performance #'s
You should post this over on the Fountain forum. With 700's Fountain claims 105+...I've heard 108mph.
FeverMike is offline
Old 01-24-2007 | 11:23 AM
dreamboater's Avatar
I think it would have to be 700's and #6 drives too. I have heard issues with the NXT drives. I saw a test with 850's and I believe the boat ran around 120mph.
dreamboater is offline
Old 01-24-2007 | 11:32 AM
FeverMike's Avatar
Yes Fountain is building boats with 700's useing the #6 drive.
Old 01-24-2007 | 02:21 PM
ToTheMax's Avatar
Are top end numbers pretty much the same with #6 instead of NXT?
ToTheMax is offline
Old 01-24-2007 | 02:50 PM
FeverMike's Avatar
Not susre but the NXT drive was not holding up to the power...so...it's not even a case weather it is faster or not. The NXT will not work period.
Old 01-24-2007 | 02:54 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Other manufacturers are doing just fine with the NXT drive.
It was posted here on OSO some time back that the Fountains were not handling well with the NXT drive, and they were being swapped for VI drives to correct the issue.
(9000th post too.)
Sydwayz is offline
Old 01-24-2007 | 04:20 PM
Pwrbt33's Avatar
Sydwayz
"You better lock it up!" <---------------POST WHORE!!!!
Pwrbt33 is offline
Old 01-24-2007 | 05:01 PM
FeverMike's Avatar
OK talked to someone in the know....Fountain still uses the NXT gimbal but puts the # 6 uppers and lowers on for better performance and durability.
Old 01-24-2007 | 05:16 PM
(9000th post too.)
Hey Brian I believe it had to do with the nosecone not being really good and efficient for the speeds they are running.....atleast thats what I heard about the 38. However I know they were having issues with the 42 due to weight....which makes you wonder why the 38 TG, and 38 Donzi are not having similar issues.
