Drive Help - Merc #6 Wet Sump vs. Dry Sump?? >
Old 01-29-2007 | 10:00 AM
Default Drive Help - Merc #6 Wet Sump vs. Dry Sump??
Hello people and how are you.... I have never had a pair of Merc 6's so I am new to the units. What is the main difference between Wet and Dry sump? Advantages, disadvantages?
Thanks in advance...
Q
TeamPSI is offline
Old 01-30-2007 | 10:50 AM
Default Re: Drive Help - Merc #6 Wet Sump vs. Dry Sump??
There is huge differences.
-Powerloss is big.
-Temperature of oil.
-The amount of oil the drive takes.
I would defiantly recommend having your drives switched from wet sump to dry sump Especially if you are looking for some good results with your boat.
Thanks, Cam-shaft.
Cam-shaft is offline
Old 01-30-2007 | 12:49 PM
-Powerloss is big.
Thanks, Cam-shaft.
Thanks for the info! How much does the conversion kit cost and who makes it??
TeamPSI is offline
Old 01-30-2007 | 12:53 PM
Contact Craig Colabella: 407-498-0094
Craig has a lot of #6 experience and used to work at Merc's Lake X. He's converting my drives now.
Dueclaws is offline
Old 01-31-2007 | 09:13 AM
sakoutis3's Avatar
Are there any physical diferences between the wet sump vs dry sump? Would a purpose built dry sump be better than a converted drive?
sakoutis3 is offline
Old 01-31-2007 | 09:41 PM
HUSTLEthis's Avatar
No physical differences, dry sumps hold 1 gal of oil, wet sumps hold 4 gal,
dry sumps have an internal oil pump, same gears,bearings,etc
I think with todays synthetic oils there is not as much of a hp loss between the drives as before...
HUSTLEthis is offline
Old 02-01-2007 | 10:13 AM
OldSchool's Avatar
It's actually closer to 5 gallons each than 4 for the wet-sumps.
OldSchool is offline
14 apache
Drives and Lower Units
6
03-31-2008 06:17 PM
SLINGSHOT
04-11-2007 06:12 PM
JCPERF
02-22-2006 09:48 PM
grand-illusion
6
03-17-2005 07:38 PM
Brad Zastrow
4
08-01-2004 05:32 PM
