Didn't winterize oops 15 degrees >
Old 01-29-2007 | 04:16 PM
THEJOKER's Avatar
Thumbs up Didn't winterize oops 15 degrees
It was 63 degress here Saturday and the cold front slipped up on me. My pontoon boat sits in the water and it wasn't winterized , surface temperature 45 degrees and it got below 17 degress last night (cup of water was frozen in my truck this am). Engine is a V-6 , well I got lucky I guess , nothing damaged. I just went out and ran around , no leaks , temperature fine. My dad always told me the surface temperature water acts as a blanket.
THEJOKER is offline
Old 01-29-2007 | 05:27 PM
FeverMike's Avatar
Default Re: Didn't winterize oops 15 degrees
Brian, go out at dusk and get the engine hot and then go out early am and crank it up and you should be OK. Leave it in the water and at least your outdrive might be ok. Go wintertize it.
FeverMike is offline
Old 01-29-2007 | 05:36 PM
Charter Member #415
Never had an engine freeze sitting in the water. The water temp is a buffer for extreme temps. If raised up on a lift,different story,but in the water,no problem. Course I am in Alabama
Magicfloat is offline
Old 01-29-2007 | 05:52 PM
Cash Bar's Avatar
Mod Squad Enforcer
39 here is S. Fla tonight.........fans coming in for the SB are gonna be pissed.......
www.gregsellswaterfront.com
Cash Bar is offline
Old 01-29-2007 | 06:01 PM
THEJOKER's Avatar
I haven't winterized in 3 years , what global warming?
THEJOKER is offline
hvyhitter19
03-09-2006 01:07 PM
JimmyBaja
7
11-17-2003 11:20 AM
PhantomChaos
01-24-2003 12:08 AM
Intolerant1
01-15-2003 10:29 PM
MooseKnuckle
03-19-2002 10:07 PM
