Go Back  Offshoreonly.com > Owners Forum > Powerplay
staggered set up. >
staggered set up.
staggered set up.
Old 02-01-2007 | 08:43 AM
Default staggered set up.
What rotation is more popular on a 33 staggered?The boat at top end tends to have too much transom lift.
Wil
SVL4 is offline
Old 02-05-2007 | 09:35 PM
Default Re: staggered set up.
Mine doesnt have transom lift.. Is that only in the stagger?
ActiveFun is offline
Old 02-06-2007 | 06:55 AM
Indy's Avatar
Member #154
I think SemperFi's boat was staggered?? Maybe he can help you.
Indy is offline
Old 02-14-2007 | 02:40 PM
Semper Fi's Avatar
Mine was staggered (HP500's) with the props turning IN. It ran well and speed was approx. 84mph with Bravo1 drives and 3 blade 29 Mirage props. The boat did run very level.
I didn't get a chance to experiment and try the props spinning out, so sorry I can't tell you much more. I can tell you that the boat was very easy (surprisingly with props turning in) to handle around the docks.
I have been told that the boat would handle better with the props turning OUT.
Semper Fi is offline
Old 02-14-2007 | 07:39 PM
Indy's Avatar
Member #154
Semper...do you have an opinion regarding 4 blade props vs. 3 blades on these boats?
Indy is offline
Old 02-15-2007 | 11:26 AM
Semper Fi's Avatar
No, only becuase I never got a chance to play around with different props. As per my conversation with Danny Weinstein awhile ago, the boat came with 3 blades because 4 blades weren't on the market at that time.
I have also been told that the 4 blade will slow it down a "hair", but give it better control and acceleration.
Old 02-17-2007 | 09:59 AM
Semper Fi's Avatar
My "old" boat is for sale in the PP section here on OSO. He is asking $79K....I sold it for $75K. Boat sits on an aluminum Myco.
Old 02-18-2007 | 01:48 PM
Andrew, put a set of shorties on it and turn the props in.....nice!
The Wizard is offline
Old 02-18-2007 | 01:56 PM
I've had both, I did like the 4 blades better, but....only if you have big power in it. If you have 500's in it, stay with the 3 blades, it'll go faster (3+)The 4 blades give you more bite, and... you need it when your accelerating hard to get on top of the next wave, I kind of miss my V bottom....
Old 02-18-2007 | 04:50 PM
Jassman's Avatar
You've been saying that 2 cat's ago Nothing like a cat for speed and stability.
Jassman is offline
