Switchable Exhaust... Illegal in Minnesota? >
Old 02-01-2007 | 09:45 AM
NoQuarter
Default Switchable Exhaust... Illegal in Minnesota?
This is a direct quote from the 2007 Minnesota Boating Guide, a summary of laws and rules
"It is unlawfull to have an altered muffler, muffler cutout, muffler bypass, or any other device designed or installed so that it can be used to continually or intermittently bypass any muffler or muffler system, or to reduce or eliminate the effectiveness of a muffler or muffler system"
A sheriff told me that if they find a boat that has exhaust that can be switched by the operator, they issue a fix-it ticket and you have 30 days to remove it and come back for a decible test. 84 dBA in MN. They let me go with just a fine because my exhaust switches automatically, but they said it's still 'technically' illegal.
Has anyone else faced this restriction in your state? What did you do?
Old 02-01-2007 | 09:55 AM
Default Re: Switchable Exhaust... Illegal in Minnesota?
Most states that have noise restrictions on the books include the switchable clause. And yes "technically" it is illegal. However if your boat will pass the restrictions in the open position they shouldn't have a problem with it.
salesmanship is offline
Old 02-01-2007 | 10:01 AM
NoQuarter
Yes I would agree that if I'm below 84 dBA even with it switched off, it shouldn't be a problem. However, the risk is that even if they suspect I'm over and want to test, part of their procedure is to board your boat and inspect the exhaust. This is the part that scares me.
Old 02-01-2007 | 10:08 AM
They're illegal in NY too. Dumb.
Pismo10 is offline
Old 02-01-2007 | 10:28 AM
NoQuarter
Yes, it is dumb. I think switchable is better for everyone. When I'm coming in at night and near someone's house, I'd switch it on to be respectful. And when I'm out in the middle during the day I'd switch it off and let it rip!
Old 02-01-2007 | 10:32 AM
tblrklakemo's Avatar
SeaRay Sundancer
It is illegal to switch from muffled to underwater? I can understand all open to all closed underwater, but why would they complicate things if your exhaust dba choices are all within the law? Oh yeah, its the govt.
tblrklakemo is offline
Old 02-01-2007 | 10:46 AM
Sydwayz's Avatar
Forum Regulator
It comes from the old laws for on road vehicles that state its illegal to have exhaust cut-outs on your automobile's exhaust system to bypass emission controls and mufflers.
So, technically, they are illegal, but I've never seen anyone get a ticket for such. The same law is on the books here in VA, as well as a mandatory baffled exhaust. Well, internal flappers and wet exhaust are legal to fit the baffled exhaust requirement here in VA. It all depends on the law enforcement official that you might piss off.
For a neat trick/safe bet; place a hidden toggle switch on your boat that overrides your dash switch. This way you can toggle your dash switch all day long in front of the officer with no effect on your Captain's Call/Silent Choice. They can't ticket you if it does not switch.
Sydwayz is offline
Old 02-01-2007 | 11:02 AM
Anything that may potentially quiet a boat should be legal.
Pismo10 is offline
Old 02-01-2007 | 11:04 AM
Charter Member #415
Been on the books in AL since 1963,and yes,came from the old days when you could unscrew caps from your exhaust. Rarely,if ever,enforced. Unless you make an officer mad over something else,you are probrably OK.In 1987 an officer jumped me about the new Merc Silent Choice on a new Glastron,told me I better remove it,but nothing else was ever said,and the boat is still on the lake.
Magicfloat is offline
Old 02-01-2007 | 11:23 AM
UNSANE's Avatar
Now that would make sense!!! But the lawmakers are thinking the other way around. They are thinking that it would make a quiet boat louder.
UNSANE is offline
