Best way's to remove paint graphics??? >
Old 02-02-2007 | 06:02 PM
Default Best way's to remove paint graphics???
is there other ways to remove paint from a boat to get it back to white gel coat other than sanding. I know it can be painted white, but at a big cost, is there a chemical, high pressure procedure, sand blasting or easy sanding method to remove it, thanks
Buddy OO is offline
Old 02-02-2007 | 07:05 PM
Default Re: Best way's to remove paint graphics???
Oven off (easy off)
burtandnancy is offline
Old 02-02-2007 | 07:14 PM
if you are very sure its gel coat under paint , paint stripper will work then just buff the sides to bring out the gel shine ,but be damed sure its gel under the paint
dmaxx3500 is offline
Old 02-02-2007 | 07:31 PM
Ovenoff only works on uncatalized paint i.e. painted pinstripes, lettering etc........also any of the liquid strippers that will remove paint have a very good chance that it will damage the gel underneath!!! if you want to do it the right way the first time, sand it off and repaint it white!!!!
and I do paint for a living so it's not secondhand knowledge.............
SUNSATION 25 is offline
Old 02-02-2007 | 07:32 PM
jryan26's Avatar
There is a product called klean strip just for that. Wont hurt the gel.
jryan26 is offline
Old 02-02-2007 | 07:37 PM
used it but still leary...............
Old 02-02-2007 | 10:20 PM
i used to build boats [24'-40' offshore]and owned a bodyshop too,dads paint works great [from wal-mart] if your careful and like i said if its white gel coat under it, it beats sanding
Old 02-03-2007 | 01:49 AM
Razor Blade The Stripes Off The Gel Then Sand And Buff It To New. It Sounds Scary But It Works.
flat rate is offline
Old 02-03-2007 | 06:38 AM
Steve_H
done it that was also. round the corners with a file so they dont dig in.
Old 02-03-2007 | 04:16 PM
tried the clean strip, very strong, don't get it on you, helped loosen paint, still took quite a bit of sanding, would take forever to do entire boat, anybody have anything else to try.
Buddy OO is offline
