Blower (Roots-style) Information? >
Old 02-04-2007 | 09:41 AM
JAdamz's Avatar
Default Blower (Roots-style) Information?
I'm looking through some boats in the classifieds and came across the "Red Cloud" Top Gun (http://www.offshoreonlyclassifieds.com/page-10447.html), and I think it's an awesome looking boat.
However, I've never had any experience with a carbureted blower setup before, and I'm curious as to what can be expected from them as far as maintenance (how often do they need to be rebuilt?), behavior of the engines around the docks, and what disadvantages come along with using blown motors. I tried searching on this topic but couldn't come across any "complete" explanations...
Thanks!
JAdamz is offline
Old 02-04-2007 | 09:57 AM
KNOT-RIGHT's Avatar
Default Re: Blower (Roots-style) Information?
That appears to be a nice clean boat.
I would recommend you have it surveyed.
Blower motors when built properly are just as good
as there NA counterparts.
They pack extreme mid range punch and provide
big horsepower gains.
I dont see intercoolers in the picture so I am assuming the boost is in the 5lbs range.
Some people like it simple I on the other hand would rather be blown then stroked.
Just my 02!
KNOT-RIGHT is offline
Old 02-04-2007 | 12:17 PM
Single With Twins's Avatar
Nice package.......very clean.
HP not over done but I would check out the Bravo 1 drives, that is its max for hp form what I understand, although they may have been beefed up.............
Single With Twins is offline
Old 02-05-2007 | 03:17 PM
JAdamz's Avatar
Thanks for the info. Right now I'm really just trying to get a general idea of what to be aware of with engines that have roots blowers; not necessarily looking to buy that boat in particular.
Anybody else have information they'd be interested in sharing?
JAdamz is offline
Old 02-05-2007 | 04:43 PM
HotPursuit's Avatar
25 yrs running roots type blowers. Never a issue have never
broke a belt.Keep oil in the front case and grease in the back bearings.Check teflon rotor edges if equiped.
Send to the factiory @ recommened inspection time.
HotPursuit is offline
Old 02-05-2007 | 04:46 PM
HotPursuit's Avatar
Just my 02!
Ditto
Old 02-05-2007 | 09:52 PM
If blower engines are built and tuned correctly, they will run and idle as good as a stock HP500 and last just as long before a rebuild.
That is Vonbongo's boat and it is done right. PM him for more info.
Griff is offline
Old 02-06-2007 | 10:02 PM
OkieTunnel's Avatar
My blower motors have been turn key for three years and counting. (525sc's turned up with more boost and carb jet changes) I push the throttle back and forth two times to prime it and fires instantly at the turn of the key. I have never had an idle problem ever. I used to break drives before upgrading to IMCO's though
OkieTunnel is offline
Coleman
Wanted
1
03-11-2008 06:27 AM
ratman
08-22-2006 10:19 PM
ghittner
3
03-22-2006 12:46 PM
gene
2
01-09-2003 05:26 PM
