575 range....?
Old 02-04-2007 | 02:09 PM
Default 575 range....?
What kind of range(miles) can one expect on a 8,000lb to 10,000lb 35'er with twin stock 575's.......I am talking 3,000 to 4,000 rpm....not wfo..........
Here's Johnny is offline
Old 02-04-2007 | 02:20 PM
Default Re: 575 range....?
Err.............how much fuel onboard?
Wayniac is offline
Old 02-04-2007 | 02:21 PM
sorry forgot to put that in there......200 gals
Old 02-04-2007 | 02:39 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
logged mileage on a trip with cig bullet an 31 scarab excell took into acount spped blasts harbor idles and cruising both had 454 365 hp Trip recap
Miles travelled Escape Klaws-579.9 Fuel 484 MPG 1.198
Miles travelled Hydrotherapy-491.8 Fuel 359 MPG 1.37
motors twins
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 02-05-2007 | 04:48 AM
ttt ......Anyone else with numbers like Klaw but for a boat with stock Merc 575's ??
Old 02-05-2007 | 02:16 PM
Canada Jeff's Avatar
I can run our tank empty in one average poker run here in the Thousand islands. 36 apache with 575SCi's. Are you lookinf for exact numbers?? They are a very thirsty engine!!
Oh, we have about the same size tank too.
Canada Jeff is offline
Old 02-05-2007 | 04:16 PM
Thanks Jeff............I would guess that your poker runs are around 75 miles like the three events NPBA holds here each year.......and at WOT I figured I would burn it up that fast. Do you get better range when not running as hard as you would in a poker run? I am asking because I know the 575's have to run on at least 91 and sometimes the 91 is hard to come by.....
Old 02-05-2007 | 04:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Get in touch with BillR here on the board. He has same setup in a 38 TS/TG, and can probably shed some info.
With a pair of 496HOs, I get about 2mpg with an aggressive cruise.
With 525EFIs, I'd venture a guess at 1.5mpg.
With 575SCis, I'd venture a guess at 1 mpg.
Sydwayz is offline
Old 02-05-2007 | 06:54 PM
t500hps's Avatar
21 and 42 footers
I had 500 EFI's with 8 psi Prochargers.....was getting about 0.8 mpg! in a 38 Formula at cruise speeds.
t500hps is offline
Old 02-05-2007 | 07:07 PM
performancemary's Avatar
Pressurized
The 575's are thursty. Every test report I have seen on these motors puts thEm at around 90 to 95 GPH at WOT. I run a 2001 PQ with the stock 575's and at moderate rpm's , 3000 to 4000, it burns close to 1 gallon per min. But is is worth every $$$$$$$
performancemary is offline
