leakdown/compression specs history
Every so often the subject comes up of should a motor be freshened ,what is acceptable lkeakdown or what should the compression be. Something every person on this board should consider doing is after dynoing their motor,rebuilding it if not dynoing it or after buying a new to them or brand new boat (after break in) is to conduct a full compression test and leakdown test. Document each cylinder on each motor and put the info where you won't lose it so later on you can go back and use it as a reference pont to see whats going on in your motor. I would suggest doing it cold because as steve xsm has mentioned and is a good point is the fact it is fairly dificult to warm your motor then conduct the test in your boat. This info could be very helpful down the line for comparison purposes,I have been doing it on all the motors I build for anything for a while,Smitty
Seems like everyone would do this but every one I ever talk to on the phone who calls with these questions never bothered to see what they had to start with,plus I see it come up every year on here,Smitty
I'll share my recent experience... A couple months ago, I pulled my motors with the intentions of just cleaning up the bilge. They were running perfect but I had three seasons on them. Since they were on the floor, I decided to do a leakdown test. On the port motor, cyls 1-3-5-7 all had between 8-12% leakage. I was pumped. Then tested the other bank... cyls 2, 4, 6 had 70-90% leakage, #2 leaking intake valve, #4 & 6 bad exhaust valve.
Starboard motor also ran perfect but found two dead holes, cyls 2 & 4 had bad intake and exhaust valves. Last night I pulled the heads on both motors and found a broken hyd roller lifter tie bar and a wiped out cam from the broken lifter.
I guess I should consider myself lucky because the last time I lost a lifter tie bar, the roller got loose and went threw the cylinder wall (at 5800 rpm) and exploded the motor.
At least I found these problems in February not the middle of July!
Kurt
Kurt
I agree completely that this is a good idea. Assuming that an initial leakdown and cranking compression test are done and the results of both are good, would a leakdown be required on subsequent tests if the cranking compression remained the same? Just wondering because leakdowns are a pita!
Dave
Dave
Compression tests don't tell the whole story. I've seen plenty of motors that have acceptable compression readings but show excessive leakage when leak tested.
Lets say you have 1 or 2 seasons and only 60-150 hours on your motors,no intentions of rebuilding yet. Before you winterize you spend a day doing these basic test every year,wow,we got a cylinder thats just along for the ride,instead of not knowing and having problems in june or july a month into boating season you have a whole winter or off season to get things taken care of. It seems mandatory to me,I'd rather know now and fix it then when its time to go boating but countless people skip this simple test every year then chase losses of speed or oil consumption issuses or worse,Smitty
,Smitty
Articfriends and Biggus,
I'm used to doing leakdowns on OB's where I turn the crank to read leakdown throughout the cylinder stroke till you get to a port.
For 4-stroke engines do you only test at TDC? I saw an old thread on "How to" but niether of you weighed in on that one.
Any other tips.
Thanks for the info!!
Any other tips.
