Slow Cooooold Start this morning >
Old 02-06-2007 | 10:15 AM
BRUCE SEROFF's Avatar
Default Slow Cooooold Start this morning
Hey guys
Had a tough time gettin my 7.3 PSD started this morning. Get plenty of crank but no start. Im assuming the fuel filter or lines gelled up. Finally got it started after about an hour of jump starting.
Is there a fuel additive that prevents gelling or enhances fuel flow in extreme cold temps?
If not, any advice is more than welcome.
Buying a new truck is not an option
BRUCE SEROFF is offline
Old 02-06-2007 | 10:31 AM
CAVelocity's Avatar
Default Re: Slow Cooooold Start this morning
Easy.... just move south!
CAVelocity is offline
Old 02-06-2007 | 10:35 AM
thats not an option either. I wish it was
Old 02-06-2007 | 10:40 AM
Bruce- do you have a block heater? most diesels do, or a crank case heater-
Talk to your Ford dealer, there are additives to help w/ gel.
wannabe
wannabe is offline
Old 02-06-2007 | 10:41 AM
CFD5's Avatar
Yes, when I had my 7.3 I used "diesel fuel supplement, Cetane Boost" Made by Power services. You should be able to get it at any auto parts store, if not try the truck stops. 1 32oz bottle treats like 100 gals.
CFD5 is offline
Old 02-06-2007 | 10:49 AM
wannabe
I do...but i cant use it. I live in a condo and dont have access to power in the parking lot. I guess i can run a generator all night, which will probably get stoloen in about 10 minutes
Old 02-06-2007 | 10:56 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
19 degrees this morning, and my 7.3 started right up at 9AM.
I plugged it in at 6AM.
Block heater is a MUST.
Sydwayz is offline
Old 02-06-2007 | 11:06 AM
Old 02-06-2007 | 11:10 AM
CigDaze's Avatar
Here you go Bruce, this is what you need. You can find it at most auto parts stores. It's good stuff.
For Cold weather:
http://www.powerservice.com/dieselfu...eboost_app.asp
And I use the grey bottle on every fill-up as a cetane booster (better mileage) and is also good for injectors:
http://www.powerservice.com/dieselkleen_cetane_app.asp
But regardless, in really cold weather a block heater is a must.
CigDaze is offline
Old 02-06-2007 | 11:13 AM
RedDog382's Avatar
Bruce,
Block heater tail should be right behind the grille. Just run an extention cord out the window and plug it in for a couple hours. It will start right up. I was able to get my '01 7.3L to start in 5* temp. It moaned, groaned, and took awhile, but it started.
RedDog382 is offline
