aluminum wheel repair
Old 02-17-2007 | 08:03 AM
mwdill's Avatar
Default aluminum wheel repair
looking for a place that can repair aluminum wheels, got one with a little curb rash on it.
mwdill is offline
Old 02-17-2007 | 08:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Will, there is a place in PA that advertises in the back of Motor Trend and the like. They say they can fix anything. Ex or the VW?
Sydwayz is offline
Old 02-17-2007 | 08:45 AM
offshoredrillin's Avatar
check a local high end car dealer will, they usual have someone like rim doctor that they use...Rob
offshoredrillin is offline
Old 02-17-2007 | 10:32 AM
Registered User
If you've got a $1500+ rim, these guys can bail you out. For others, the expense can be as much as a new rim.
Chris Sunkin is offline
Old 02-17-2007 | 01:33 PM
mwdill's Avatar
neither,
the cobra, scuffed it pretty good yesterday, it wouldn't be that bad but it's the 10'th anniversary wheels, can't find many used ones, but new the they are not bad about 180$.
mwdill is offline
Old 02-17-2007 | 01:36 PM
mwdill's Avatar
i figured as much, just wanted to check.
there might be someone local that can do it, just not sure how well, really did not want it look like crap.
mwdill is offline
Old 02-18-2007 | 10:05 AM
Will, as I said, check with a high end dealer, or call your ford dealer and ask them who they use. I have seen it done by a professional in a couple hours and he charged about a 100 bucks....
Rim Doctor
3900 Crystalwood Ln
Richmond, VA 23294
804 901 2109
Old 02-18-2007 | 10:07 AM
Registered User
Originally Posted by mwdill
neither,
For $180, it wouldn't be worth the time looking them up and calling.
Last one I had done had a minor bend in the bead and a scuff- cost $600. New wheel was $2200 so it was well worth it.
Old 02-18-2007 | 07:55 PM
There is a franchise around called Wheel Fix It. Not sure if in you area but worth a try. Typical repair anywhere from $75 to $125.
nashpda is offline
Old 02-18-2007 | 08:29 PM
Was going to say check with a used car dealer that does higher end stuff. Had a guy with a wheel fix, paintless dent removal, stone chip touch up and even re-die of leather interiors. This guy was mobile and most dealers have a hook up for someone like described!
Zudnic is offline
