Power Stroke problems
On the way to Cinci tonight my truck started makeing a noise up around 3k rpms, sounded like the turbo was about to fly appart. I slowed down and got off the interstate and white smoke was pouring out the exhaust. Any idea what the problem is??
Registered User
Although not a good idea, the motor will run with a completely seized turbo, although not too well. If it lunched the bearing, it took the seal with it and it's spraying oil into the exhaust- you'll eventually run the motor dry. I drove a wounded CAT from DC to Ohio on a weekend once with just that very problem. I crushed the oil supply line shut with vice grips.
Its a 7.3, I havent made it back out to pop the hood since it cooled off. I was running 3k RPM the whole way down just to go 75mph. Didnt think too much of it tho becase I was driving straight into a very stiff wind and had an entire boat interior standing straight up in the bed catching a lot more wind. I called every single Ford and Int. dealer in the area, and of course none of them will have a Diesel tech on duty until Monday.....grrrr
-Thrill
-Thrill
yeah tell me about it. Funny thing is OSO "Scott" called me and was on the way north from Cinci in a crew cab super duty *****ing about the wind too. Looks like Im stuck here until Monday at least. Bass Pro is right around the corner and theres an indoor range around the other corner so I guess Il have some time to get re aquainted with my carry gun
Registered User
Sounds like a good reason to go and buy a NEW gun.
Too bad it's not next weekend, there's a show in Sharonville.
Hey, I just e-mailed you about UMP parts. Don't know if you can get it where you're at. If not, PM me.
