Header recommendation please >
Old 03-04-2007 | 07:39 AM
Default Header recommendation please
I'm really confused on this.Read every thread on headers and still dont know which headers to buy.
I've got a 1997 Scarab 23 502mpi with the cast iorn exhaust manifold which has to go.I want some very nice,light weight headers for the boat.
Can someone tell me what headers I need and where to get them.Also,since the motor will be breathing a little better will the ECM need to be remapped or programed?
Prostreeter is offline
Old 03-04-2007 | 07:50 AM
You could just throw on a set of gil manifolds, if you want to spend the extra moneyput on cmi or stelling. Unless your modifiying the motor the headers are not going to make a huge performance difference. If you are planning on procharging the motor the gils will be fine, or stainless marine would be a good choice also.
RonS is offline
Old 03-04-2007 | 08:01 AM
Thanks for the input.Looks like I was making this more difficult than it is.I think the Gil manifold is a good idea and will look into that.
Old 03-04-2007 | 08:23 AM
Stainless marine works great on 502 efi,lasts forever you also should use long (aprox 20) tailpipes on that engine.That engine is very prone to reversion with stock length tailpipes.
MDGperformance is offline
Old 03-04-2007 | 10:11 AM
Eddie marine and Imco have a nice set of the log style headers.
hoosier272 is offline
Old 03-04-2007 | 11:27 AM
articfriends's Avatar
The stainless marine manifolds are butt ugly but work very well,especially if you have intentions of adding a procharger in the future,Smitty
articfriends is offline
Old 03-04-2007 | 02:47 PM
cariveau's Avatar
Default Revolution Marine
For your boat a set of Revolution Marine headers are going to work great. They are also very low cost and come in polished or powder coated cast aluminum.
cariveau is offline
Old 03-04-2007 | 06:50 PM
I suggest the CMI Uni-Top headers..not real expensive but very nice looking..And they will give more room to winterise or change/check plugs
Bajapred is offline
Old 03-04-2007 | 07:09 PM
nocigarette's Avatar
by stainless marine noting compares on the dyno...............plus ya get a warrenty
Attached Thumbnails Header recommendation please-magnum-105.jpg   Header recommendation please-magnum-118.jpg
nocigarette is offline
Old 03-04-2007 | 07:10 PM
ttt
