twin 283 gm big blocks
Old 03-04-2007 | 12:22 PM
Default twin 283 gm big blocks
i just became the new owner of a 68 criss craft , the motors havent been started for 8 years , any advise?
lawless47 is offline
Old 03-04-2007 | 12:25 PM
drain tanks
flush lines
put in fresh gas hit with some AMSOIL powerfoam in carb..and fire up??
worked on my old 283 in my Chris
powerqrudy is offline
Old 03-05-2007 | 09:35 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
283's are small blocks You should probably also do a good tune up, oil change & a carb rebuild may be needed.. Jamie / lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 03-05-2007 | 10:01 AM
tblrklakemo's Avatar
SeaRay Sundancer
Is it a roamer?
tblrklakemo is offline
Old 03-05-2007 | 12:43 PM
RHC's Avatar
RHC
The old 283 Chris motor has solid lifters,, if it has set for 8yrs it might have the rings froze to the pistons ,,, I had to pour some of my Vodka and Orange juice down the Carb so there was enough compression to light off the Starting fluid ,, that was after 2 starters were burned up,,,, dont try to re-wire that thing ,,, it is installed backwards ,,, wow ,, what great memeories that thing was,,,, after it fired we ran it for about 1hr and the rings loosened up and it was a very good motor ,,,, have fun !!!
RHC
RHC is offline
Old 03-05-2007 | 12:55 PM
Knot 4 Me's Avatar
RHC
Simple enough to put a breaker bar on the balancer bolt and see if the motor will turn over by hand first to see if the rings are stuck. If so, pull the plugs and shoot some penetrating lube in and let soak.
Knot 4 Me is offline
Old 03-05-2007 | 02:45 PM
Try these sites for a lot of info and a good resource for parts too:
http://www.network54.com/Forum/424840/
http://groups.yahoo.com/group/cccommander/
rdoactive is offline
Old 03-05-2007 | 10:41 PM
cuda's Avatar
Marvel Mystery Oil is THE best down the plug hole to free up an engine. Trust me.
cuda is offline
Old 03-06-2007 | 01:37 AM
I know this works on Pontiac engines, and I think it will work on Chevy's, too. Take the handle off a blade screwdriver, and put the driver in your drill chuck. Take out the distributor, and put the blade down the hole until it contacts the oil pump shaft. Turn on the drill motor, and build up some oil pressure for about a minute. Now your bearings are primed with oil, so they won't start up dry. I would also put some oil in the cylinders, too, as others have mentioned.
Michael
Michael1 is offline
Old 03-06-2007 | 04:49 AM
TeamSaris's Avatar
Driver-441
Racer
prime the **** out of em
TeamSaris is offline
