Removing Factory Controls? >
Old 03-05-2007 | 10:16 PM
Default Removing Factory Controls?
I am trying to get the handle off of my Quicksikver control. I was told to look for an allen screw, but have not had any luck. Some info would be greatly appreciated.
Dwayne
DKerns is offline
Old 03-06-2007 | 01:08 AM
Might have a cap or plug over it.
Griff is offline
Old 03-06-2007 | 05:49 AM
Mine has an allen set screw on the bottom that faces the gunnel, it's hard to see.
David Stotz is offline
Old 03-06-2007 | 07:25 AM
jjj
(Merc 3000 classic) I believe the allen screw is visible when you move the throttle fwd. the slot will line up with the screw. It is a friction adjustment.
To remove the shifter/throttle lever, you must pull out the neutral button then a nut will be visible to remove the handle
jjj is offline
Old 03-06-2007 | 05:31 PM
Thanks for the info, I will check it out Tomorrow.
DKerns is offline
Old 03-07-2007 | 08:48 AM
Knot 4 Me's Avatar
And to pull out that plastic button, you must push it in and have the shifter moved forward in the "throttle only" position. Otherwise you will break it trying to remove it.
Knot 4 Me is offline
Old 03-07-2007 | 09:58 PM
I found the screw. Someone must have had problems with it backing off, they filled the hole with black silicone. Thanks for all the info. Has any one used the Teleflex controls? I want to upgrade while the interior is out.
DKerns is offline
onesickpantera
08-21-2007 08:20 PM
BDevlin
General Racing Discussion
46
01-12-2005 08:23 PM
rchevelle71
2
04-20-2004 09:13 AM
dawiz74
03-07-2004 08:33 AM
