Brass plugs  .... >
Brass plugs ....
Brass plugs ....
Old 03-06-2007 | 02:20 PM
offthefront's Avatar
Default Brass plugs ....
These brass Hex plugs are about twice as long as they need to be ... I got them from McMaster-Carr .... I have seen some that when tight are flush or close to Flush .... Suggestions ?
offthefront is offline
Old 03-06-2007 | 03:27 PM
Panther's Avatar
Frank's Marine Service
try a different brand or get a tapered pipe tap and run the tap thru the manifold a little further.
Panther is offline
Old 03-06-2007 | 03:29 PM
I used polished S.S. plugs available at most plumbing wholesale outlets. I also bought the pipe thread taps to redo the holes in the intake manifold. You have to be careful with the aluminum, and if you run the taps to deep its harder to get them to seal but the result was the plugs are now flush.
Dave
David Stotz is offline
Old 03-06-2007 | 03:33 PM
nocigarette's Avatar
unless it bothers ya leave it...................or.... i use aoroquipp fittings they fit pretty flush...
nocigarette is offline
Old 03-06-2007 | 03:59 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
How many threads are actually ingaged?
US1 Fountain is offline
Old 03-06-2007 | 06:59 PM
About 1/2 the plug ... the 1/2" plugs are 5/8 lomg .. there's about 5/16 out ...just bugs me ....
Old 03-08-2007 | 08:38 PM
Buy a 1/2" pipe tread tap and make them exactly as you want. Every other method is a guess and a waste of time. You can use a 12 pt socket and ratchet and skip the cost of a t-handle.
BenPerfected is offline
KH0302
Prop Talk
2
10-17-2007 05:41 AM
offthefront
6
02-08-2007 03:49 PM
CRUBOSS
01-31-2003 12:04 PM
TulsaLarry
12-16-2002 03:27 PM
