Anyone Running a Drive oil temp gauge >
Old 03-06-2007 | 02:44 PM
Sick Stinger's Avatar
Brotherhood #1
Default Anyone Running a Drive oil temp gauge
I was just wondering if any one was running an oil temp gauge on a leg and if so how did you set it up. If there are any pics. that would be nice also
Mike
Sick Stinger is offline
Old 03-06-2007 | 03:00 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
I have gauges, but it was rigged at the factory and I never really payed attention to how it was rigged. Sorry It can and has been done though
The drive temp gauges are the lower ones next to the steering wheel.
WARPARTY36 is offline
Old 03-06-2007 | 04:26 PM
Brotherhood #1
O Ok thanks war my real question is then does it have the sender in the top of the leg, oild res. or in the side of the leg. Also where do your temps stay and does your boat have a shower on it for the drives
Old 03-06-2007 | 04:35 PM
WARPARTY36's Avatar
I don't know where the sender is The gauge doesn't move at idle or no wake. Actually it doesn't move unless I'm running pretty hard. Yes, I have drive showers so that may help on the temps.
Old 03-06-2007 | 04:37 PM
Brotherhood #1
Thanks again war its ok any help is good help
Old 03-06-2007 | 05:08 PM
BY U BOY's Avatar
It Is Mounted In The Side Of The Drive.
BY U BOY is offline
Old 03-06-2007 | 05:15 PM
Brotherhood #1
Thanks By i kinds figuers there or on the top of the drive im thinking of running one
Old 03-06-2007 | 05:34 PM
screws in the top vent hole.
Allen
29scarab10 is offline
Old 03-06-2007 | 05:38 PM
Brotherhood #1
O ok that is even better no dilling requiered thanks 29
Old 03-06-2007 | 07:04 PM
Default Out Drive Temp
I Run One It Screws In The Top Vent Hole And It Does Not Move Unless IM On The Gas And Up On Plain On A Hard Run It Will Run 250 Deg.
dennis r is offline
