Support for cabin hatches >
Old 03-06-2007 | 08:22 PM
Moses's Avatar
Default Support for cabin hatches
I am trying to glue the support arm for one of my hatches back to it. So far I tried Gorrila glue and a two part epoxy that said it was rated for two tons. Neither glue worked. Any help or suggestions would be great.
Moses is offline
Old 03-06-2007 | 09:20 PM
JasonSmith's Avatar
Drill it out & put a dowel in there, then glue it. Or you could send it to me & I can extrusion weld it for you, but it won't look pretty & I'd probably f*ck it up more than it is right now.
Just curious, how much is a new one?
JasonSmith is offline
Old 03-07-2007 | 06:54 AM
Ditto:
Can it just be replaced with a new one?
imartin is offline
Old 03-07-2007 | 08:09 AM
I need a new support arm for my 33 OL. Does anyone know where to get one?
JRalston is offline
Old 03-07-2007 | 10:47 AM
Moses's Avatar
The arm that attaches to the hatch popped off. Kinda like a review mirror to a windshield. The manufacture must use a product to attach them as they make em.
Moses is offline
Old 03-07-2007 | 11:06 AM
yzbert's Avatar
i was told they weld it on. some type of special plastic weld? i can not think of what they called it. i do know there was no one in great white north that did it though.
yzbert is offline
Old 03-07-2007 | 11:14 AM
JasonSmith's Avatar
Extrusion welding is the kind of weld. Basically heats up a plastic rod feeds it thru a heated tube in the gun & spits it out the other end. It is pretty easy to do yourself, although it is nothing like regular metal welding.
The Eastwood Co. makes a small scale plastic welder that is realitivly inexpensive to purchase, but I think you could buy a new hatch for what it would cost to buy the welder.
I would take it off & go to a body shop. Most large body shops have plastic welders & could probably hook you up.
Again, I would just buy a new one.
Old 03-07-2007 | 11:29 AM
Moses's Avatar
Thanks for the info. I like the idea of buying the welder even if it costs more than buying a new hatch. Another reason to buy a new tool is OK with me. Scott your a Dentist you counldn't make some crazy epoxy that would keep it from falling off.
Moses is offline
Old 03-07-2007 | 12:07 PM
yzbert's Avatar
no i glued it three times before i found out that it was plastic welded.
yzbert is offline
Old 03-07-2007 | 02:12 PM
Wally's Avatar
Were doomed!
are they both made of plastic or is the support made of aluminum or some other metal? Ive had some realy good luck with some stuff called weld-on by IPS corp http://www.ipscorp.com/ stuff is strong when it comes to joining acrylic...ive busted the acrylic before the joint failed!
When you tried that epoxy stuff....did you sand the mating surfaces to have a clean bond surfaces or just go right ontop of the old glue/adhesive? that may be the problem why it didnt bond too...
-Wally
Wally is offline
