Thermostat Housings Again
OK, OK, I know this has been beat to death but I still have a question. I did a search and read through all the past posts but still cannot find the answer.
Question,
I am looking for a two hose bypass housing. I like the OEM Merc style. Even better, I like the S.S. unit one by Sierra. I have been told there is a specific one for Bravo and a different one for Alpha drives. I need the one for an Alpha drive SBC setup. Can anyone help ?
Thanks, Dave
Question,
Thanks, Dave
David,
I am going through the same ordeal. You can get new ones from a mercruiser parts vendor. They are a bit pricey. From my research, the stainless one from Sierra cross references to the alpha part. I just could not find a Sierra part in stock anywhere.
Dwayne
Dwayne
DKerns,
Thanks for the reply. I'm going to check with some of the local supply houses. So, in your research there are two different ones ? One for an Alpha and one for a Bravo ?
RedDog,
I'm not looking for the stock units. I'm looking for housings that use one cooling to hose to each exhaust manifold.
RedDog,
