proping 502's 415 hp 1996 35 fountain lighting 1 step >
Old 03-09-2007 | 01:15 PM
TOMMY HIWAVE's Avatar
Default proping 502's 415 hp 1996 35 fountain lighting 1 step
was running 27 pitch hydromotive props 68 mph 4800 rpms.
tried bravo 1 26 pitch ran 72 at 4800 rpm 40 degrees outside.
what prop should i try next was looking at 26 pitch hydo's now not sure
TOMMY HIWAVE is offline
Old 03-09-2007 | 04:35 PM
25 hydromotive 4 blades should get the job done
runafever is offline
Old 03-09-2007 | 05:17 PM
jryan26's Avatar
My 1995 single step w/hp500s came from the factory with 28 Mach? props.
jryan26 is offline
Old 03-09-2007 | 08:22 PM
ALL IN's Avatar
i have a 92 35 lighting 502's and i have 26 hydro's 72 steady 75 all the right things (low fuel,no people,no beer)turning4900 rpm's i know you have a step not sure how that would play out.
ALL IN is offline
Old 03-09-2007 | 08:47 PM
H2Xmark's Avatar
which direction are you turning the props Tommy?
H2Xmark is offline
Old 03-09-2007 | 10:09 PM
out
Old 03-10-2007 | 08:57 AM
25 hydros spinning in should put you at 4950 on the 502s. Might need 26 depending on where you boat( I.E. elevation, air density)
Old 03-10-2007 | 10:07 AM
rickdarling's Avatar
I have the exact same boat with 496 Mag HOs (which are almost the same HP). I'm running 26 pitch Bravo 1s (turning in) and get 5150 Rs. It seems to me that you should be doing better than the 4800 you indicate..
rickdarling is offline
Old 03-10-2007 | 06:57 PM
we have the exact boat
Attached Thumbnails proping 502's 415 hp 1996 35 fountain lighting 1 step-p1010066.jpg
Old 03-10-2007 | 06:59 PM
funny
