spark plug for stock 502?
I'm wondering what kind of spark plugs to get for my 502 mag. Stock (rebuilt), carbureted.
I searched the forums and found references to a projected tip design providing the best results. There seem to be a lot of recommendations for the NGK BPR6FS or the BR6FS, and also for the a/c MR43TS
Should I go with an extended tip?
Will i have any issues with piston clearance?
Will I gain anything?
Yes, you can use the extended tip.
Also consider the A/C RapidFire part # 1
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Champion RV12YC, AC MR43T or MR43TS, NGK BPR6FS. The plug basically goes in perpendicular to the piston so xtnd tip clearance is not an issue. .045 I believe.
