Merc 600 SC's
Old 03-12-2007 | 07:24 PM
From: Ft. Lauderdale Florida & Tarpon Springs Florida
Default Merc 600 SC's
Am going to switch to Xr's with Sportmaster lowers.. Does anyone have info on adjusting the boost on the Super Charger on the 600SC I was told they come from Merc with only around 5-6 lbs of boost but can be brought up to in the 12-14 range. Any info?? reliability, worth it ? etc... Thanks
tanner is offline
Old 03-12-2007 | 08:51 PM
GLH's Avatar
GLH
The new 600SCi's or the older 600SC.
As for reliability with 12-14# of boost... It will be an enjoyable 20 minutes.... whatever the model.
GLH is offline
Old 03-12-2007 | 11:54 PM
Stock should be 6# of boost on a 600SC. Its a 420 blower. You could probably go 8# with an inner cooler and still be reliable.
Griff is offline
Old 03-13-2007 | 08:04 AM
WildWarrior's Avatar
From the factory they are set @ 5 lbs tops and you cant add more than a lbs or so of boost before you totaly beat up the air and she make less hp .
You really need an innercooler to see a "MAJOR" differance in power from stock.
We put 7lbs to our 600SC, AFR heads,JE 8 to 1, Crane roller cams with stock carbs we ran out of cfms @ approx 5000rpms..With our added 900cfm carbs our 600scs had our TopGun close to the mid 90s and that was with her side vents removed and engine hatchs lifted a few inchs. Without scoops you cant get enough air to your carbs on the Gun. We tosted stock Bravos with stock power, then with added power toasted a few brand new Max Machine Worx drives on our Kevlar Topgun.
You may also want to grab an extra input shaft from the Blower Shop for your 420s, even with stock boost they are the weak link esspecialy when you turn up the wick. The 600s are great engines and will run a long long time.If you put an innercooler and a few lbs to them you will feel it and still have reliable power,just be carefull getting on plain.. I would keep mine around 2800 to 3000rpms while getting on plane with a ton of tab.
Good Luck!
WildWarrior is offline
Old 03-13-2007 | 08:51 AM
jdnca1's Avatar
I know someone that runs 10# of boost with a chiller on a pair of 600SC's; runs large hydralic roller, stock heads, and has flat tops in (~8.4:1)...on 93 Octane, making close to 900hp. Its been a very reliable set-up.
jdnca1 is offline
tanner
6
04-25-2007 06:13 AM
MACTONITE
2
08-25-2005 01:17 PM
Superbabi
14
03-06-2005 03:24 PM
Chuck
11-30-2004 04:56 PM
