9.5 to 1, am i going to have to run 91 gas? >
Old 03-12-2007 | 10:39 PM
nxfirebird's Avatar
Default 9.5 to 1, am i going to have to run 91 gas?
the motor's a basic bbc 4.35" bore x 4" stroke deal, aluminum heads, 228 - 238 @ 0.050 marine cam. i'm i going to be stuck with running good pump gas?
how much timing am i going to beable to get away with? i'd like to be in the 33-34 degree range total.
if i have to run good gas i might as well order bigger chamber heads and the M-1 procharger....
thanks
nxfirebird is offline
Old 03-13-2007 | 06:38 AM
The aluminum heads buy you some compression, standard marine 89 will probably work.
Pismo10 is offline
Old 03-13-2007 | 07:25 AM
I am sitting at 9:5 and timing set at 36 BTDC. I always run 91 and would not think of running anything else. I can not afford to have a meltdown
1BIGJIM is offline
Old 03-13-2007 | 11:57 AM
socalstone's Avatar
You'll probably be ok -especially with Aluminum heads.
It also depends on the shape of the combustion chamber/piston configuration. Good circulation/swirl = 89 will be fine.
socalstone is offline
Old 03-13-2007 | 12:22 PM
Yes, a small chamber with a large quench pad and close piston-head clearance will also allow higher compression on pump gas.
Pismo10 is offline
Old 03-13-2007 | 03:08 PM
nxfirebird's Avatar
the heads would be the Edelbrock 110cc chamber ovals for the 9.5 to one build.
Old 03-13-2007 | 03:32 PM
Pat McPherson's Avatar
What ignition are your running?
Most of the new stuff has knock protection.
If you don't go wild on the total advance, you should be good with 89.
Patrick
Pat McPherson is offline
Old 03-13-2007 | 04:27 PM
My ZZ502/502 has/had 9.6:1 with aluminum heads and GM recommended 92.
Kidnova is offline
Old 03-13-2007 | 05:24 PM
IRONMAN's Avatar
89 octane will be fine with the 34 timing as long as your fuel curve is good and you run at 140 - 150 deg
Don't be surprised if you make more power on 87 with less timing though.
IRONMAN is offline
Old 03-14-2007 | 09:32 AM
nxfirebird's Avatar
right now stock, but i'm going to get MSD stuff for it when the motor goes in.
