Trailer Tire Question
Old 03-16-2007 | 01:28 AM
jayhawk261's Avatar
Default Trailer Tire Question
I have a 24' Superboat on tandem axle trailer. Total rig weight would be around 3500 lbs I'm guessing. The stock wheels are 13". I am considering upsizing the tires as it seems to me that a taller tire may give a little more contact patch area and give a little better stability.
If I change, what will the detrimental factors be for the brakes and bearings? Will a straight swap be just fine affecting noting else? Obviously the ball mount will have to be changed out to one with a little less drop.
Thanks!
jayhawk261 is offline
Old 03-16-2007 | 04:57 AM
mama tryed's Avatar
Thanks!
Jay, Your not going to have a lot of options in a 13 inch,, I think a 185/80R13 is the biggest "ST" Tire you can get,, and that should be plenty for what your towing, the load rating is 1480lbs per tire, 6ply, overall dia. is 24.7 inches, width is 7.2 inches
a ST175/80R13 is 1360lbs per tire, 6ply, 24.0inches-O.D., and 7.0 inches wide.
Hope this helps!!
FYI,, to give you an idea on cost, we sell the GY Marathon 185/80R13 for 55bucks, so don't let your local dealer try to "Break it off" if you know what I mean!!
Mitch
mama tryed is offline
Old 03-16-2007 | 01:12 PM
jayhawk261's Avatar
I was actually thinking about moving up to a 14" or 15" wheel. The tires I have now are the ST185/80R13.
Any thoughts on that?
Old 03-16-2007 | 02:59 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
As long as you have fender clearance, I don't think you will have any issues going to 14". I am not familiar with the bearings in a hub behind a factory 13" wheel. What are the individual axle load ratings?
www.championtrailerparts.com can sell you entire wheel/tire packages. However, stay away from Carlisle Trailer Tires. Marathon trailer tires are the way to go. Cooper also makes ST tires, but I have no experience with them.
Sydwayz is offline
Old 03-16-2007 | 03:28 PM
Default Axles
How close are the axles/tires?
If you put 14 inch wheels tires will they rub tire to tire? Measure the space between the tires now. If less than 2 inches I would not bother.
You probably have 2500 lb axles, maybe 4 bolts holding each wheel on?
You are probably ok with current set up, just stay at 65 mph or lower.
Wannabe
wannabe is offline
Old 03-17-2007 | 04:23 AM
mama tryed's Avatar
Here's some numbers for ya to check your clearances
205/75R14 Width - 8.0 inches , O.D. - 26.1 inches
215/75R14 Width - 8.5 inches , O.D. - 26.7 inches
205/75R15 Width - 8.0 inches , O.D. - 27.1 inches
Old 03-17-2007 | 12:26 PM
jayhawk261's Avatar
Thanks for the info. I will check out the numbers and see what I can do. In my situation, am I going to see a benefit from going to the larger tires/wheels, or will it be a waste?
Old 03-17-2007 | 01:15 PM
mama tryed's Avatar
My thoughts are, less revolutions per mile means longer tire life, less heat build-up which is the major cause of tire failure, and a higher load carring capacity.
Old 03-17-2007 | 02:41 PM
jayhawk261's Avatar
Wannabe
It has 5 on 4.5 bolt pattern now. I can't remember the trailer manufacturer name right now though. I have no idea what axle rating they are.
jmackin
11
04-15-2008 02:00 PM
masi242
8
04-01-2008 05:42 AM
Donzi Corleone
13
02-02-2008 12:33 PM
patrick22309
08-06-2003 07:45 PM
