Looking at a 28 with no motor and BMAX
A friend of mine is looking a a 28 TD with no motor. Thinking about an 800 hp procharger motor. The main concerns are balance of the boat front to rear and low speed spray and handling 35-45 mph. Doesnt want a "dog"down low. Anyone on here or know of someone that has one or knows that he can talk to?
Ive heard the same thing. tall decks need twins. I think thats why they dont put out any new tall decks with a single. Ive noticed allot of older 28 tall decks and you never see them with 496,500, its allways a teague 800 or big blower motor which tells you all that power is needed to push it around. Then they blow up outdrives. Maybe its a good price?????
A pair of 600 hp will get a TD over 100 no problem. If driven right, XRs or XZs will last quite a while, just make sure you check the bearings and gears every 50 - 100 hours or have drive temp gauges.
It will spray over the front in rough water under 55 mph, it really likes 75 to get up on top.
If you're going with a single, get a Konrad or #6.
planes way easier and cruise speed is much improved
