Fountain Bolster Foor Mounts
Has anyone had an issue with those six bolts in the floor (3 per bolster seat) that don't seem to get "tight"? I thought these were thru-bolted like everything else but they are feeling like lag screws - ugh! Perhaps the nuts are simply turning on the other side of the bottom??
If they are thru-bolted, how do I gain access to tighten them up? If they're not thru, how did you guys fix this?
Thanks!
Thanks!
Now I dont claim to be an expert on this but I believe they are lags. If you cant get them tight then take them out and mix up some epoxy and inject it into the holes with a hypo. Let it cure and drill them out with a bit that is comensurate with the bolts and put them back in. You may want to call fountain on this.
knew i could count on some good answers. this site and the folks on it are fantastic! despite a few minor shortcomings (that any boat would have), i LOVE Fountain boats -
Long Live The Beak.
Long Live The Beak.
I've had the same problem on my 2000 - 29' Fever...The lag screws work out and then they won't tighten down and are stripped... I thought about seeing if putting in lag shields or something different would work better...I think you would have to remove the seats to do that though...If anyone has a better fix I'd love to hear it...I agree, one of the only poor design features on the boat
twinzilla
01-17-2007 02:39 PM
