Which headers should I go with? >
Old 03-21-2007 | 04:34 PM
Default Which headers should I go with?
Ok this post was in another forum but since there are still a lot of stock 502's out there I wanted to get some broad feedback.
Basically the stock Mercury exhaust on my 2001 502 EFIs are shot and it looks like I bent a valve due to water leak between the manifold and riser.
Since it's 2 motors, I'm looking for low cost or gently used replacement. So far the best prices are Revolution $1200 pair and Dana Marine $1750 pair.
If $$$$ wasn't an option I would lean towards CMIs but I got some good advice that that's overkill for a stock motor.
I'm leaning towards the Dana's since they're a little more performance oriented.
Any suggestions or better deals elsewhere?
strikeforce is offline
Old 03-21-2007 | 05:29 PM
Sent ya a PM.
Baja Pete
baja pete is offline
Old 03-21-2007 | 05:32 PM
Strip Poker 388's Avatar
Rob
stainless marine ?
or
eddies?
Strip Poker 388 is offline
Old 03-21-2007 | 06:52 PM
cuda's Avatar
Neither of them are technically headers, they are performance manifolds. I just put a set of Dana's in Deb's 22 Donzi.
Attached Thumbnails Which headers should I go with?-1-2-07-006.jpg   Which headers should I go with?-1-2-07-003.jpg
cuda is offline
Old 03-21-2007 | 06:57 PM
Might want to check out the lightning lineup good performance,cool looks, and prety durable.
sschafee01@snet.net is offline
Old 03-21-2007 | 06:59 PM
used cmi headers
johnlomant is offline
Old 03-21-2007 | 07:05 PM
CPPerformance's Avatar
Gil / Hardin system would be a good choice for you at $1899.99 complete with EVERYTHING you need to install including relocation brackets, bolts, gaskets, and turbulators. More Info Here. Let me know if your interested and I'll shoot you OSO price.
Thanks,
Brad
CPPerformance is offline
Old 03-21-2007 | 09:26 PM
Too Old's Avatar
Toss EMI Thunders in the mix. 5 year warranty, competitive pricing, all brackets included.
Stainless Marine, sligntly more money, five year warranty, excellent reputation.
Lot's of choices.
Too Old is offline
Old 03-21-2007 | 09:48 PM
AIR TIME's Avatar
Thumbs up
I have had my stainless marine since 94 and there still good unless someone gets through my new alarm and steels them , ps check with trick marine for SM or EMI prices fred stands behind his stuff, oh I run in salt water but flush after use.
AIR TIME is offline
Old 03-21-2007 | 10:33 PM
Thanks guys, a lot of good choices here EMIs are looking good and there are some CMIs that can be had but a little more work to install. I gotta decide in the next day or so.
