496 mag question >
496 mag question
496 mag question
Old 03-22-2007 | 08:38 PM
Default 496 mag question
how can you pressure test this system i have a slow leak that i cant seem to locate
Baddogg is offline
Old 03-22-2007 | 08:58 PM
Knot 4 Me's Avatar
Does the leak only occur in cold weather?
Knot 4 Me is offline
Old 03-23-2007 | 09:00 AM
No I T Has Leaked All Season Very Slow
Baddogg is offline
Old 03-23-2007 | 09:44 AM
I assume you are having a water leak. If so this may be from the winter/ water dump system. If you have a little air left in there it may be enough to crack these valves open when the engine heats up. Pull the air relief valve when the engine is hot, and see if this takes care of it.
Island Hopper is offline
Old 03-23-2007 | 09:59 AM
Knot 4 Me's Avatar
Mine leaks antifreeze in the winter when it is really cold. I believe there was a TSB from Merc on this where the hose clamps that hold the heat exchanger in place were installed too tight from the factory and need to be loosened and repositioned...or something along those lines.
Old 03-23-2007 | 12:00 PM
Wink pressure testing a 496
Get a hold of a Stant pressure tester that most automotive shops use to pressure check cooling systems on cars. There is an adaptor that Stant makes that is designed to screw onto screw type cap systems that threads perfectly onto the coolant overflow bottle on a 496. Pump up the tester to about 13-14 lbs and let it sit for a bit. If the pressure starts dropping it indicates a leak in the system and you should see the orange coolant tell-tale leak where your problem is as long as the leak is external and not internal in the engine. This is how we check 496 coolant system integrity.
Hope this helps.
Regards,
Ray @ Raylar
Raylar is offline
Old 03-23-2007 | 03:24 PM
thanx raylar leak is outside motor i see a small drip now and then it is just really hard to determine where it originates i think it may be an o ring thanx for your input
Baddogg is offline
apexer
2
08-05-2008 11:46 AM
TeamPSI
23
12-10-2007 05:23 PM
SlickNick
05-17-2006 08:11 PM
chrisf
01-14-2006 11:31 AM
TEAMBAJA
3
09-10-2004 10:22 AM
