Oil In Distributor Cap >
Old 03-25-2007 | 05:58 AM
Craney's Avatar
Default Oil In Distributor Cap
I'm getting oil up in my distributor,not a lot but after but 3 or 4 out you will see some oil in it. Its MSD are there any seals I can replace or do I have to buy a new distributor?
Craney is offline
Old 03-25-2007 | 03:51 PM
monstaaa's Avatar
i believe there is a bushing / seal under the shaft which is turned bu the cam gear.
you ll have to remove the drift pin at the bottom of the distributor, which runs thru the gear. after that you ll be able to lift the shaft along with the reluctor out of the distributor housing and have a better view.
good luck.
monstaaa is offline
Hydrolift
5
06-19-2007 11:16 PM
zimm17
4
05-26-2007 06:19 AM
paxtonsc
12
04-23-2006 06:57 PM
wildcard
4
05-14-2003 08:31 AM
Jayl13
6
05-28-2002 06:22 PM
