Transom Degree >
Transom Degree
Transom Degree
Old 03-29-2007 | 10:17 AM
Default Transom Degree
Does anyone know what degree the transom was built on a 1998 26'?
ThruHull is offline
Old 03-29-2007 | 08:37 PM
Call the factory. i have always had good luck with them. If no one knows they usualy give you Steve or they have him call you back.
Padraig is offline
Old 03-30-2007 | 11:13 AM
I called and talked to Tim at the factory, he said it was a standard 24 degrees. Someone else told me it was 13 degrees and the standard was between 12 and 15. I am just trying to be certain before CMI makes this exhaust.
ThruHull is offline
Old 03-30-2007 | 12:59 PM
Revelocity's Avatar
24 degrees is the hull deadrise - not the transom angle. You better call back but don't use the term deadrise this time.
Revelocity is offline
Old 04-02-2007 | 07:32 AM
VelocityMark's Avatar
Call back and ask to speak with Steve himself. He will either answer or he will call you back.
VelocityMark is offline
Old 04-02-2007 | 11:24 AM
Just got off the phone with Kenny at the factory, 24 degrees is the deadrise, 16 degrees is the transom angle. Just thought I would post this in case anyone else runs into the same problem.
ThruHull is offline
Old 04-02-2007 | 10:42 PM
Did you end up going with the Unitops?
Revd Up is offline
Old 04-02-2007 | 10:53 PM
Yeah ordered them today, said it would be a two week lead time, hope they are good on there word!
ThruHull is offline
Clay Washington
South Central US
3
07-28-2008 08:58 PM
WETTE VETTE
10
08-28-2005 07:05 PM
open87
6
07-15-2005 02:56 PM
DanL
6
05-21-2002 04:00 AM
