tilt trailer bad for motors? >
Old 03-30-2007 | 08:57 AM
Default tilt trailer bad for motors?
i was just thinking would a tilt trailer be bad for the motors leaning on an angle for that long?
Outkast Rafe is offline
Old 03-30-2007 | 09:08 AM
as long as the oil is pumped out of the motor you can not hurt it. if you have a wet sump just add a dry sump tank and pump it out before you tilt and then pump it back in before firing the motor. If you have a dry sump motor the oil is already out of the engine and you just tilt away. also you have to put non venting caps on your trim pump tanks to keep that fluid from coming out.
bgchuby01 is offline
Old 03-30-2007 | 11:59 AM
i dont have one i was just wondering im a newbie trying to learn this stuff
thanks
Old 03-30-2007 | 01:14 PM
Sean H's Avatar
A to Z
and make sure your fuel tanks are vented to the high side of the tilt trailer too...
Sean H is offline
KNOT-RIGHT
38
10-12-2008 10:26 AM
BLee
09-30-2008 09:38 AM
keirmon
17
06-26-2007 03:50 PM
LubeJobs42
03-04-2006 08:54 PM
JMPH
Fountain
6
11-02-2005 11:41 AM
