Boring 454 Mag-385 .220 over >
Old 04-01-2007 | 07:09 PM
Default Boring 454 Mag-385 .220 over
A 454 Mag 385 hp has all the steel internals of a 502 mag.
The diameter of the 454 is 1.250
The diameter of the 502 is 1.470
The difference is 0.220 (220 thousandths)
Can this be done? and then can you get your ECU reflashed and have a 502?
jerosejr is offline
Old 04-01-2007 | 07:33 PM
Elite Marine's Avatar
Default Here's some reading for you
http://www.offshoreonly.com/forums/s...ore+stroke+502
Elite Marine is offline
Old 04-01-2007 | 08:10 PM
OOPS
Meant to say 4.250.
So I guess the article mentioned above says that it can be done.
Has anyone ever done this? Is it too much bore?
Would it be better to go the 496 route?
jerosejr is offline
Old 04-01-2007 | 08:13 PM
No, they are different blocks. The 502 is a siamese block.
Griff is offline
Old 04-01-2007 | 08:28 PM
Fenderjack's Avatar
Pirate of the Chesapeake
No you can't bore a 454 to ,make it a 502, not enough cylinder thickness . The 502 is a different block although the stroke is the same. Go to a 4 1/4 stroke and make it a 496.You can bore your 454 to a 60 over with no problems. John
Fenderjack is offline
Old 04-01-2007 | 09:09 PM
Got it !!!!!!!!!!!!!
Thanks guys.
jerosejr is offline
Old 04-01-2007 | 09:40 PM
If the 454 Mag is MPI, after the bore and stroke to 496, can the ecu be reprogremmed for the new size?
jerosejr is offline
Old 04-01-2007 | 09:59 PM
What exactly is your goal?????? To make more HP?????? or something more specific????????
Griff is offline
Old 04-01-2007 | 10:17 PM
Make more power at 3500 rpm.
swing a larger prop in an inboard application.
jerosejr is offline
Old 04-01-2007 | 10:48 PM
Whipple Supercharge it. Make 600hp and lots of midrange torque.
Griff is offline
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
fbh-velocity
1
07-29-2007 03:49 PM
JCCRAZY
02-28-2003 06:11 PM
MIdnightRider
Fountain
5
03-15-2002 06:50 PM
