How high can a 502mpi rev limiter be adjusted? >
Old 04-01-2007 | 09:10 PM
Default How high can a 502mpi rev limiter be adjusted?
I have a friend that runs a procharged 502mpi and weve been talking about raising the rev limiter. I am thinking 5800-6000. The thought is to rev it higher with a smaller pitch prop and reduce stress on the drive and inprove holeshot as well as acceleration.
HPJunkie is offline
Old 04-01-2007 | 10:07 PM
If its a stock cam, it will rapidly start losing torque beyond about 5200rpms.
Griff is offline
Old 04-02-2007 | 12:05 AM
articfriends's Avatar
If your asking if the mefi3 ecu can be raised that high the answer is yes,mine is,Smitty
articfriends is offline
Old 04-02-2007 | 07:12 AM
Michigan Mad Man
I can set your Rev Limit up to 6000 Rpm on the Mefi 3. The newer Mefi 4's can go to 9000 RPM. Tyler 8103242720.
TylerCrockett is offline
Old 04-02-2007 | 02:12 PM
Thanks Tyler,
I do have another question though. If I set the fuel pressure up to give the proper o2 reading on top end then the idle mixture will be rich? Ive heard of a resistor that "fools" the temp sensor to think the motor is warmer than say 120 degrees therefore keeps the motor out of cold start mixture. ( all of this because of the no thermostat procharger setup) can this be fixed with your programming?
Greg
HPJunkie is offline
Old 04-02-2007 | 02:44 PM
Elite Marine's Avatar
Yes you can change the value in the ECU. Or change the pulse width on the injectors at the idle RPM and MAP.
Tyler is the man when it comes to setting them up properly!!
Mark at Precision is good too, but Tyler can do it in your boat and he's in MI
Elite Marine is offline
Old 04-02-2007 | 03:54 PM
How can I tell if I have a mefi 3 or 4?
HPJunkie is offline
Old 04-02-2007 | 08:40 PM
There's two MEFI 3 ECU"S. Ser. no end with 099 or 999.
Not too many 999's. Either will work. Just different programing.
Noise Pollution is offline
Old 04-02-2007 | 10:08 PM
Michigan Mad Man
Thanks Tyler,
Greg
I can program the ecu so you will not need the box. I will never be right adding all the extra boxes.
Old 04-03-2007 | 12:23 AM
Tyler,I wanted to raise my rev limiter when I dyno my motor with you again in a few months,you already have it set to 6000,can we eliminate it completely and just use my msd pills or will I need to convert to a mefi-4 to go to 6400? Smitty
