Removing gimble housing studs?? >
Old 04-03-2007 | 06:33 PM
VinMan's Avatar
Default Removing gimble housing studs??
Anyo know a good way to remove the thru hull studs on a gimble housing? The ones I have are pretty corroded.
They feel like they will snap if I keep trying to turn them.
VinMan is offline
Old 04-03-2007 | 07:29 PM
Laken's Avatar
I would use a gimbal housing stud remover tool
sorry I couldnt resist that comment.
Laken is offline
Old 04-03-2007 | 07:47 PM
RedDog382's Avatar
I am trying to do the same thing also, but not having much luck. Really don't feel like replacing another $1500 gimbal housing if I break off a stud. You could try a little heat around the studs, but it would probably lift the paint.
RedDog382 is offline
Old 04-04-2007 | 02:06 PM
VinMan's Avatar
Ive soaked them for a week in PB Blaster , Havent tried the heat thing yet. I 'm not too concerned about the paint. Im just afraid of snapping it.
VinMan is offline
Old 04-04-2007 | 02:07 PM
VinMan's Avatar
Mercruiser P/N?? In other words BIG pipe wrench!
VinMan is offline
Old 04-04-2007 | 02:10 PM
rws's Avatar
rws
Heat the aluminum casting around the stud,Aluminuim has a faster rate of thermal expansion than steel .
rws is offline
Old 04-04-2007 | 02:31 PM
Mr Gadgets's Avatar
Charter Member #601
I use a stud removal tool that has three rollers in them to grasp the stud, heat the housing with a heat gun slowly.. bring up to temp. You can get it hot enough to hurt when u touch it.. with a heat gun and not hurt the paint. I would try bouncing on the wrench easy.. to see if it wil break loose. Is that stud SS or just steal?? I have done the above procedure with SS studs.
Hope that helps.. good luck!
Mr Gadgets is offline
Old 04-04-2007 | 03:04 PM
Salt water huh?
Been there.
Propane torch. 2 nuts on the fine thread end. Put a wrench on it. Then a few whacks with a hammer. Have a beer and start over.
You know, the standard methods. Sorry, dont know any easy secret method.
rdoactive is offline
ggharley
Drives and Lower Units
2
07-22-2008 04:09 PM
VinMan
2
11-05-2006 11:27 AM
gotime34
4
07-25-2005 11:41 PM
KENNY
5
12-30-2002 05:57 PM
