Go Back  Offshoreonly.com > Owners Forum > Powerquest
7" or 11" tips? >
7" or 11" tips?
7" or 11" tips?
Old 04-14-2007 | 10:19 AM
Default 7" or 11" tips?
I want to replace my Corsa mufflers with angle cut tips from Rex Marine but can't decide between the 7" or 11" tips.
MacGyver is offline
Old 04-14-2007 | 09:37 PM
Fast Forward's Avatar
Just be careful about the bolt pattern. I had purchased a new set of 7" last year and when I went to install them the holes were off. I decided against drilling new holes and re-sold them.
Fast Forward is offline
Old 04-14-2007 | 09:59 PM
Were they from Rex?
MacGyver is offline
Old 04-15-2007 | 05:05 AM
I don't recall where I bought them from. I know my 23 Conquest I changed out and I did buy them from Rex and they worked fine. But it had standard non-muffuler tips on it to start with.
Old 04-15-2007 | 07:55 AM
BillR's Avatar
OSO Moderator
The Corsa tips use a std 3 bolt pattern. There were once 3 -340 Vypers here, and we replaced the Corsa tips on all 3. (12 tips in all) They all matched pretty well - as long as the factory guy was having a good day and drilled them correctly.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-15-2007 | 05:32 PM
jus roamn's Avatar
jus roamn
Hey BillR, did you guys use the straight cut tips and put the external flappers back on? I was going to buy the angle cut ones at first but I'm concerned about water reversion with the tips being so close to the waterline. Also were they from Eddie Marine or CP? Thanks for any input!
jus roamn is offline
Old 04-15-2007 | 10:32 PM
I just replaced the tips om my 290,the bolt were off,but thats an eazy fix,just get some plexus and fill the holes and redrill them if you have to.
boatnt is offline
Old 04-16-2007 | 11:33 AM
Macklin's Avatar
Bill went with angle tips on his. Not sure about Vyper340. I took the non-muffled tips (with flappers) that came off Bill's boat and sold my muffled tips. Then gave the money to Bill.
I like having the flappers for added protection. The only time you can see them is when the boat is out of the water anyway.
Macklin is offline
Old 04-16-2007 | 01:49 PM
BillR's Avatar
OSO Moderator
I went w/ internal flappers.
If you want tips, I know someone selling a set of 4 Eddie Marine slash cut tips w/ internal flappers. BRAND NEW - still in bag.
Part #100-08 $ 200 all 4
He also has a used (40 hours) set od 4 slash cut tips - no flappers
in good condition. $ 100 for 4
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-16-2007 | 04:45 PM
jus roamn's Avatar
jus roamn
Hey Bill,
Could you PM me the phone number for the guy with these tips? I was thinking more of the straight cut ones , but if you used angled ones without any problems, I might give them a try. Thanks again!
