37 X_Dimension
It is not crooked smart A S S!!!!
Yes, I have a 1 inch spacer in the drive. It does not matter about that where I measured. I measured off the TRANSOM ASSY. (on the inside of the drives) down too the bottom of the boat. So if you go from there it does not matter if ytou have a spacer.
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Your prop is higher..not the drive.
If I understand this the top of ya'lls drives are at the same place below the rubrail.
The spacer puts his prop lower...to correct for that "nose bleed" drive height.
Yes you are so right, if your drive is 10 inch's also then try a 1 inch spacer and you should pick up like I did. I went fron 24% slip to 14% slip by getting the prop in cleaner water. Hole shot is ALOT better and cruise also.
