Adding pitch? >
Adding pitch?
Adding pitch?
Old 04-17-2007 | 06:22 PM
Ratickle's Avatar
Default Adding pitch?
How much pitch can be added to a prop? For instance, if you have 27 pitch props, and add blowers, can you pitch the props you have up to 31/32?
Ratickle is offline
Old 04-17-2007 | 10:18 PM
You will need new props repitch can add 1-2''
mmwalters is offline
Old 04-17-2007 | 10:21 PM
Coolerman's Avatar
PF Marine
Sweet, keep us posted with pics and numbers! You dyno'ed em' yet?
Coolerman is offline
Old 04-17-2007 | 11:17 PM
1" up or down on SS props is what I have been told.
Griff is offline
Old 04-18-2007 | 07:47 AM
throttleup's Avatar
We can change the pitch one inch on a SS Bravo Stern Drive propeller.
Julie
throttleup is offline
Old 04-18-2007 | 08:40 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Actually you can add a couple inches but the root pitch won't change because it is cast or welded into place.
We are comfortable with one inch adjustment up or down. there are also cupping changes that effect rpm and indeed change over all pitch.
[email protected]
bbladesprops is offline
kilroy
Prop Talk
5
05-17-2007 03:09 PM
crb76
1
10-06-2006 05:33 PM
kilroy
04-07-2005 05:30 PM
Steamin Rice
2
09-28-2004 05:15 PM
Highmark
Baja
3
03-18-2004 08:14 PM
