deep cycle  batteries cca's  vs   mca's >
Old 04-18-2007 | 10:56 PM
26sonic's Avatar
Default deep cycle batteries cca's vs mca's
I have a 02 496 ho engine , was told that battery should have at least 1000 mca's . looked at the sears die hard platinum deep cycle that had 850 cca's . is there a conversion from cca's to mca's ?
26sonic is offline
Old 04-19-2007 | 08:23 AM
Ted G's Avatar
From Oddyssey batteries:
Define the difference between MCA and CCA.
The marine cranking ampere (MCA) rating of a battery is very similar to the CCA rating; the only difference is that while the CCA is measured at a temperature of 0°F, the MCA is measured at 32°F. All other requirements are the same — the ampere draw is for 30 seconds and the end of discharge voltage in both cases is 1.20 volts per cell.
I don't think there is an exact conversion but 850 would be fine.
www.cbpba.com
Ted G is offline
Old 04-19-2007 | 12:10 PM
Strip Poker 388's Avatar
Rob
I would think also 850 would be plenty
Strip Poker 388 is offline
96f350psd
13
01-18-2009 07:14 AM
26sonic
02-08-2007 04:20 PM
rude
New Products and Member Discounts
0
10-19-2006 06:36 PM
MrsDigger
6
05-27-2005 10:23 AM
baja 272
20
03-16-2003 11:49 PM
