What all do i need?
I have a 07 f350 dually with factory brake controller, 15K receiver, and im gonna be pulling a 38 Top Gun on a myco.
What size drop hitch do I need?
Do i need anything for the factory brake controller to work?
Do i need air helper bags?
Thanks!
Thanks!
You should be good. I have an old heavy top gun with a Myco tripple axle. and I drive a Chevy 3500 dually. I have a 10k drop hitch that is adjustable and it works great.
80 mph on cruise control from Tampa to Virginia. The only problem was the rear end singing on mile marker 17 in NC. I roasted the rear after a pre trip fluid change to Jiffy lube, and they put what looked like water into my diff.
Stay away from them and you wont have a problem.
My Myco is very well ballanced, I don't think that you will even know it's back there.
Good luck!!
Good luck!!
Measure the trailer tongue height with the trailer cranked up level and then put that up next to the back of your reciever. My guess is that you wont need any drop other than the regular 1 or 2 inch. Other than that...happy towing and sweet boat.
