Does Virgina have ethanol in its fuel >
Old 04-19-2007 | 02:06 PM
stageharbor's Avatar
Go Big or Go Home
Default Does Virgina have ethanol in its fuel
I Brought a Boat up from Virgina to Maine for a customer. and need to know if there if ethanol fuel in the tank. Maine has mtbe in the fuel.
stageharbor is offline
Old 04-19-2007 | 02:52 PM
Ted G's Avatar
Va uses ethanol
www.cbpba.com
Ted G is offline
Old 04-19-2007 | 03:07 PM
As far as I know Oklahoma is the only state that does not put ethanol in their gas - guess were I fill up at......
TexomaPowerboater is offline
Old 04-19-2007 | 03:29 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Became mandatory in Virginia as of May 1st, 2006. I just heard on the news last night that a new study is indicating that Ethanol is "worse" for the environment and public health? I know it's worse for my boat's fuel system....
Reckless32 is offline
Old 04-19-2007 | 03:50 PM
t500hps's Avatar
21 and 42 footers
Not all of VA has it.....some of the very rural areas do not run it.....I used to tow out of the way to fill with non-ethanol fuels.
t500hps is offline
Old 04-19-2007 | 04:34 PM
TRUE. In my county they don't have it & one county over they do.
Brian C is offline
Old 04-19-2007 | 06:10 PM
Go Big or Go Home
Thanks The boat came from Virgina beach.
Old 04-19-2007 | 06:19 PM
99fever27's Avatar
Do you know if the pumps around Anna have it? Their pumps arent marked for it.
99fever27 is offline
Old 04-19-2007 | 06:50 PM
t500hps's Avatar
21 and 42 footers
Defintely had ethanol there.
t500hps is offline
Old 04-19-2007 | 09:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Metropolitan area... more than likely.
I don't believe the counties around Lake Anna have Ethanol.
Off the top of my head:
Henrico: Yes
Hanover: Yes
Caroline: No
King William: No
King & Queen: No
Prince William: Yes
Pumps are to be CLEARLY marked "Contains 10% Ethanol" if its in the mix. Linster had a map showing all of the counties that have and don't have.
Sydwayz is offline
