Gimbal Ring Repair Made Easy >
Old 04-22-2007 | 06:35 PM
Default Gimbal Ring Repair Made Easy
I thought I would share with you my Gimbal Ring repair using Ron Benders method. http://www.jrmarine.com/
Ron also supplied the three wrenches needed.
The total project from start to finish took me 6 hours.
1BIGJIM is offline
Old 04-22-2007 | 06:37 PM
Drilling out the template took me 45 minutes.
1BIGJIM is offline
Old 04-22-2007 | 06:38 PM
To make the removal easier I drilled a 3/8 hole in the middle and took a small pry bar to start the removal process.
The directions say use a die grinder. I could not use my straight grinder so out to buy and Small air Angle Grinder.
1BIGJIM is offline
Old 04-22-2007 | 06:40 PM
Project completed.
NOTICE – if you buy parts remember to install them!
I bought a stainless U-bolt from Ron and forgot to put it in. I almost took it back apart but I had the clearance set by the time I noticed.
Overall a very good product and Ron was great to work with. I highly recommend using this product.
1BIGJIM is offline
Old 04-23-2007 | 04:50 PM
Just did the same repair myself a couple of weeks ago, Ron was great and I was always able to get him on the phone when needed
ckentling is offline
Old 08-10-2007 | 09:47 AM
wowchad's Avatar
I used his kit too and I'm a believer!
The bellhousing and all the bellows & cable was intimidating but I had a member from here stop by my shop to give we a hand, THANKS JIM (32 caliber)!
wowchad is offline
Old 08-10-2007 | 03:23 PM
And what did you have to do with it? I really need to fix mine so could someone explain what he did here other than get access to it. Thank you.
Brandon is offline
Old 08-10-2007 | 03:30 PM
wowchad's Avatar
http://www.jrmarine.com/instructions.htm
wowchad is offline
Old 08-10-2007 | 03:41 PM
So do you have to take drive and bellhousing off to do this? I am really sorry for all the dumb questions guys but thank you for taking the time to help. It is appreciated very much!
Brandon
Brandon is offline
Old 08-10-2007 | 09:58 PM
G Man's Avatar
Will this work on a TRS drive?
G Man is offline
