Dock Flotation Question >
Old 04-24-2007 | 01:10 AM
atxwellcraft's Avatar
Default Dock Flotation Question
I am looking for encapsulated flotation for my dock. I have regular styrofoam now and I am losing pieces. I would like to redo everything with encapsulated but I am unsure of what kind to buy. Has anyone heard of Dock Buoy? It seems to be the best priced. Any suggestions would be helpful. Thanks in advance
atxwellcraft is offline
Old 04-24-2007 | 05:46 AM
I bought some of Overtons brand. They were very high quality and I have been happy with them. They were expensive and expensive to ship.
SkiDoc is offline
Old 04-24-2007 | 10:05 AM
I did overtons as well. Expensive plus shipping. They were odd sizes as well, had to trim edges here and there to make fit but they work great. They are styrofoam encased in heavy black plastic, so even if they ever leak a little, no big deal.
Pismo10 is offline
Old 04-24-2007 | 10:38 AM
You should try to get plastic floats filled with styrofoam or some other material. I built a large floating dock last year, used DockEdge flotation (Howell 400) that have worked very well, except they are simply air inside and I'm pretty sure that one has punctured over the winter due to ice movement. If they were filled with styorfoam, etc, it wouldn't fill up with water. Good luck.
http://www.dockedge.com/products/doc...ion/floats.asp
bouncedcheque is offline
Old 05-08-2007 | 12:25 AM
Does anyone know about Dock Buoy flotation specifically?
Old 05-08-2007 | 12:53 AM
can you just cut a hole in it and fill it with something like the foam you pour around gas tanks?? or theres the poor mans blue plastic barrels/drums...
phragle is offline
Old 05-08-2007 | 01:22 AM
if its for a pond, you can use the plastic drums but most lakes have restrictions against them now.. if you need some drums for a project, let me know.. ive a ton of them at my warehouse..
waterboy222 is offline
u150
02-02-2008 07:32 PM
ericaull
11-19-2006 01:05 PM
atxwellcraft
05-08-2006 11:26 PM
atxwellcraft
2
01-19-2006 10:34 PM
283CHECK
11-21-2002 10:21 PM
