Go Back  Offshoreonly.com > Owners Forum > Powerquest
Questions about Batt. Charger & Hatch Accuator >
Old 04-25-2007 | 10:30 AM
rrentsch's Avatar
Registered User
Default Questions about Batt. Charger & Hatch Accuator
Just picked up my 34' last weekend and am now trying to find out how everything works. There has been alot of talk here about hatch accuators failing,mine works really slow, it does appear that it is wired with 10 ga. wire. If it fails how do you get the hatch up to change it ?. 2nd question, My boat has 3 batteries, 2 battery switches and a C-charger brand battery charger, my question is do the battery switches have to be on to charge the batteries ?
rrentsch is offline
Old 04-25-2007 | 04:09 PM
If your hatch lift is connected like mine you can open it with no power, just lift hard on the hatch to over come the initial resistance. The end of the accuator rod should just be a slip fit into the bracket under the hatch.Next time you have the hatch open lift on it by hand and the rod from the accuator should pop out. I am not 100% sure and depending how every thing is wired i believe the switches need to be on for charging.
johnny b good is offline
Old 04-26-2007 | 09:34 AM
Default Battery charger
Where is your battery charger located ? I purchased mine back in August and it has a breaker for the charger but i dont see one in the engine bay, is it under the floor area ? How can i tell if i have one ?
laszlo01 is offline
Old 04-26-2007 | 11:39 AM
PWRQWST's Avatar
I turn my bat switches on "all" while I charge mine, it seems to work that way other wise I don't believe it will charge otherwise. I lift my engine hatch every weekend, it is heavy but I ordered my new lift this week. Good luck.
Rich.
PWRQWST is offline
Old 04-26-2007 | 08:36 PM
performancemary's Avatar
Pressurized
Default battery charger
The charger is mounted to the bulkhead just in front of the port engine. PQ alwys has several circut breakers on the pannel that are available if you want to add an option that the original buyer did not order.
My Viper was the same way. It didn'y have a charger but it had a breaker for it. Also had a breaker for hot water and other things the the boat was not ordered with.
performancemary is offline
Old 04-27-2007 | 06:12 AM
Is it relativly easy to install a charger if your boat was not equipped with one ?
laszlo01 is offline
Old 04-28-2007 | 08:18 AM
I believe so.Try going to a local marine supply store( West Marine ) and they should be able to walk you thru the install. Plus they will have any of the little things you need to finish the job.
Old 04-28-2007 | 09:10 PM
Default To PWRQST
Yuo mentioned you just ordered a new lift, where from. Is yours now wired with the #10 ga.??
Let us know how the new one works out.
boater-rs is offline
Old 04-29-2007 | 07:52 PM
rrentsch's Avatar
Registered User
Default Sun Pad Lift Cylinder
I checked my sun pad lift cylinder this weekend, the cylinder rod is pinned directly to the underside of the pad. If it fails can you still force the sun pad open with the cylinder rod still attached ?
rrentsch is offline
Old 04-30-2007 | 06:16 AM
Yes
the rod slides inside the cylinder
boatnt is offline
