Any reaso not to pressure wash? >
Old 04-27-2007 | 04:03 PM
jayhawk261's Avatar
Default Any reaso not to pressure wash?
Any reason not to pressure wash my 454 Mag MPI in the bilge at the car wash? If I do the whole compartment am I risking contaminating the trim tab and drive reservoirs? Are the electronics hearty enough to withstand the power wash? It just seems like a good thing to do before getting to work on the tune up.
jayhawk261 is offline
Old 04-27-2007 | 04:46 PM
You'll have different thoughts on this but I've done it many times on my scarab and no issues at all.I dont wash the engine at all.Water will spray on the motor but not enough to hurt anything.I'm pretty darn picky when it comes to having a clean engine compartment and boat in general.Like I said,I do it all the time.
Prostreeter is offline
Old 04-27-2007 | 05:26 PM
BY U BOY's Avatar
I do it evrey time i use the boat. I just make sure that i only use high press under the engine and slight press for every thing around the trim pump and batts.
BY U BOY is offline
Old 04-30-2007 | 07:32 AM
Canada Jeff's Avatar
I wrecked an MSD distributor on a carbed engine from washing it with a preasure washer. I did it more than once. Moisture got into the spark advance and rusted it out.
Just FYI....
Canada Jeff is offline
JeffC
Detailing, Painting, & Fiberglass
7
03-20-2008 08:10 PM
vendetta
Awesome
21
08-17-2007 03:21 PM
betitbig
03-12-2006 08:55 AM
Scott
01-22-2002 08:58 AM
