Anybody Built There Own Oil Pan >
Old 04-29-2007 | 05:22 PM
nocigarette's Avatar
Default Anybody Built There Own Oil Pan
I was wondering if any of ya have made your own oil pans, like extented wings on you gil 8 qts. to make thenm 12 quarts...........Just curious i did and the pan has a hell of a time sealing to the block.....
nocigarette is offline
Old 04-29-2007 | 08:41 PM
Hydrocruiser's Avatar
Arrow
We got pans...but they aint good without oil...too much fighting...bed pans... pans beat oiul pans...
Hydrocruiser is offline
Old 04-29-2007 | 09:18 PM
2112's Avatar
I had two built by Stef's. I run external wet sump pumps. They were 100% built from the rail up, all stainless, no leaks, expensive.
2112 is offline
Old 04-30-2007 | 03:56 AM
cig1988's Avatar
I have 2 Gill's in the swap section. One is like the the other "needs help".
cig1988 is offline
Old 04-30-2007 | 07:06 AM
rws's Avatar
rws
My dad has built some custom application dry sump pans
(mostly circle track),and i have built a few wet sump pans.Did you build a fixture to hold the the pan rails when welding,or even bolt it to an old block?Perhaps things moved from welding.
rws is offline
Old 04-30-2007 | 02:28 PM
2122
Do you have a photo of your external wet sump pump?
powerabout is offline
Old 04-30-2007 | 03:38 PM
2112's Avatar
Originally Posted by campbelljenkins
2122
The pump is at the very bottom. It is a single stage Aviaid. They are small but great to work with. What I like most is the adjustable oil pressure.
2112 is offline
Old 04-30-2007 | 04:16 PM
I am using the newest Peterson Wet Sump pump with the KE cast alum pan with the build in oil pump mount.
BenPerfected is offline
Old 04-30-2007 | 06:32 PM
This is what i think happened it is leaking just when i put it under high rmp.....When the crank is pounding oil around it starts to seep, i made a 8 qt gil a 12 qt.......It just suck i have to pull the motor to fix the pan......Oh well all aero quipp fitting and a few trans and bracket bolts........I am thinking 3 hours tops....Motor out pan pulled fix pan on a decked bench, ram motor back in fire up and see if it is leaking........
Old 04-30-2007 | 07:35 PM
2112's Avatar
one lesson I learned is you can't set the engine down on the pan after you installed it and expect it not to have a leak. Now I always keep in on a stand, on a dolly(motofeet actually) or in the boat.
2112 is offline
